Registrato Thu, 14 Jun 2018 21:00:00 GMT di Michael Weingand Professional Services Manager
When opening the desktop Administration tool. I have to type in the Organization each time.  Must not have written to a config file.  All works fine just want to see if anyone knows what config file I can edit this in.
Registrato Fri, 15 Jun 2018 06:35:12 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
In DocuWare.Administration.exe.Settings make sure that this line is complete. There can be multiple entries so make sure the one with  the Organization is the first occurrence in the list.
<AuthenticationServers>
      <ConnectionSettings Name="Standard AS" Server="myserver" Port="9000" Organization="XYZ" Local="false" Active="true" System="Central system" />
    </AuthenticationServers>
You will find this file in the DocuWare Client folder under C:\Program Files (x86)\DocuWare
