Registrato Tue, 27 Mar 2018 18:05:30 GMT di Craig Heintz SE
When I create a form and it stores it to DW Cloud it seems that the form is stored with the fillable fields.  If I then choose edit document and it opens it up in Adobe Reader, the form fields are there and the data can be changed and saved.
Is there a way to set the forms package to store the forms created as an image in DW so that this form field formatting is lost.
We do not want folks changing the data on these forms but the need to retain the ability to edit other type documents.
We have considered cabinet profiles but I think it will get  very complex.
Please advise what my options are.
Registrato Tue, 27 Mar 2018 18:09:46 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Craig,
We recognize this as a problem. It is addressed with DocuWare 7.0. There currently is no work-around.
Registrato Tue, 27 Mar 2018 18:15:03 GMT di Craig Heintz SE
OK, thanks and thanks also for the super quick response.
