Registrato Thu, 29 Sep 2022 16:55:24 GMT di Jalila Manal
I've designed a workflow to check the expiry date of some documents, and send a notification to the person/people assigned to the ones that will expire soon.
In my workflow, I have a variable(V1) that take the assigned to information, and then I put it on the "To" field to send a notification.
This is working fine when I have only one person in the Assigned to field, so I've introduced another variable (v2)=replace(cstr(GV_V1),",","; "), where I replace "," with ";" and then I put it on the "To" field, but this is not working.
Any ideas to make it work please?
Thank you in advance.
Registrato Fri, 07 Oct 2022 00:00:25 GMT di Matthias Wieland Senior Director Support EMEA
Dear Jalila Manal! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-187452-X1K0D for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
