Registrato Mon, 12 Nov 2018 12:53:00 GMT di Craig Heintz SE
I have 1 Pro Server license and now 1 Web Client Read Only License.
Will I be able to set the read only web access on another server or do I need another Pro Server license to do that?
My intention is to have the normal access on one server and the read only access on another server.
Registrato Mon, 12 Nov 2018 22:14:51 GMT di Josef Zayats
Craig,
you can isntall an addditional Platform instance on another Windows Server with IIS as it does not require any additional Docuware server licenses and direct your RO users to use PlatformRO website on that server.
The only thing is - if you want users to be using Desktop Apps that require user licenses such as C2O and SmartConnect on RO site, you'd need to adapt web.config file on that server to set ReadOnlyMode=True
