Registrato Thu, 21 Feb 2019 01:25:26 GMT di Craig Heintz SE
Is there a way to do a one time removal of all INACTIVE users in a cloud account?
A sync was done with the USERS node of AD and now there is a ton of clutter in there.  Using the search tool helps.
Just seeing if there is a way to clean it up.
Registrato Thu, 21 Feb 2019 10:05:34 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Craig,
Unfortunately you need to remove them manually one at a time.
Registrato Thu, 21 Feb 2019 11:48:49 GMT di Craig Heintz SE
OK, thanks for the info.  Good news is if you fix the way the sync grabs users that it automatically deactivates the user.  I have over 6000 that were grabbed, so they will remain!
