Registrato Thu, 08 Mar 2018 13:31:00 GMT di John DeLaat
Can DocuWare Mobile be setup to store documents from the Document Tray into DocuWare?  I do not see where I can configure the Document Trays/Store Dialogs using DW Cloud 6.12 for mobile.  Also, can you configure the Mobile App to be able to turn off and on the Task Lists a user is assigned to?
Registrato Thu, 08 Mar 2018 13:47:32 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
With Mobile:
You can import a document to a Tray.
You can store a document to a file Cabinet.
You can Search a File Cabinet.
You can act on Tasks.
You cannot view a Tray.
You cannot store from a Tray to a File Cabinet.
If you have a mobile license, a user logged in to DocuWare Mobile will see all Tasks, and be able to search within their rights assignment. There is no "Usable in Mobile" option in 6.12 as in previous releases.
You cannot turn off the Tasks list in Mobile.
Registrato Tue, 07 Jan 2020 12:57:01 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Even if the thread is quite old, I would like to update it with the information for the current version of the mobile app.
The response from Phil is valid for the now called "DocuWare Classic" app.
The current DocuWare can now do the following:
  • You can share a file from another app to a document tray
  • You can search in a file cabinet
  • You can act on tasks
  • You can view documents in a document tray
  • You can store a document from a document tray to a file cabinet
You cannot do:
  • You cannot share a file from another app directly to a file cabinet
  • You cannot import a file from inside the DocuWare app
