Registrato Wed, 07 Mar 2018 16:21:12 GMT di Josef Zayats
Anyone knows where the connections are 'remembered' and stored in the file system for a user?
Can't find any in %appdata% nor in %temp% nor in registry.
Registrato Wed, 07 Mar 2018 16:38:31 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
ProgramData \ DocuWare \ Desktop \ Secure \ [Users Windows Security Identifier] \ userconfig.xml
Registrato Wed, 07 Mar 2018 17:25:26 GMT di Josef Zayats
Phil,
thank you very much! This certainly explains why I'm having problems losing desktop connection in non-persistent VDI environment where ProgramData Folder is reset to its original state every time a user logs in. So every time a connection needs to be recreated either manually or by having cliet open for 2 minutes.
Do you know if the location can be changed somehow to point to %appdata% instead? Even if some functionality (when user is not logged in) is lost?
