Toggle navigation
Forum
Knowledge Base
Stato
Download
Richieste di supporto
Tutto
Tutto
Pagine Web
Forum
Articoli della Knowledge Base
Filtro di Ricerca
Tutto
Pagine Web
Forum
Trova risposte
Italiano
Deutsch
Español
Français
English
日本語
Italiano
Accedi
Home
Forum della comunità
Questions about usage and configuration
Conversion from PDF to JPEG for better results before send to tray
Registrato
Mon, 23 Nov 2020 07:29:29 GMT
di
Tiago Matos
CoreForm Business Technology -
Software Implementation Specialist
Hi all
We have an customer that is already using DocuWare but it is not happy with the manual work required once the tray OCR result don't bring supplier name and ABN(Australia Business Number) from document header.
I was checking the PDF on adobe reader and looks like the header of the PDF is a image and the rest of the document is a normal PDF structure.
After some tests we figure out that converting the PDF to JPEG before importing to tray, improved the OCR result bringing the supplier name and the ABN.
So we are thinking to provide an solution that is going to convert the PDFs to JPEGs before importing into the tray.
This issue is only happening for just some suppliers documents. But they receive a lot of documents from these suppliers.
The customer is receiving all documents via email so one solution could be:
Solution A:
- Create an app the is going to read the account payable email inbox folder
- For each email
- Get the attached PDFs and convert to JPEG.
- Create a new email with the same subject and email body
- Attached the JPEG images
- Move the original email to /pdf folder
- Send email to the final email that DocuWare is reading
Please feel free to give any advice or ask any question.
Quick note. (I imported the same document into Amazon Textract and the OCR result was much better.)
Tiago
Screenshot 2020-11-23 182731.png (472,3 KB)
Registrato
Wed, 25 Nov 2020 03:43:35 GMT
di
Craig Heintz
SE
Try this
KBA-36285
I have found it overcomes the poor ocr on pdf image files. This is mainly needed for v7+ as it used to be set to "true" in version 6
Registrato
Wed, 25 Nov 2020 05:09:15 GMT
di
Tiago Matos
Hi Craig,
Thanks for helping.
Sorry but I forgot to say that we are not using Desktop Apps to import documents into DocuWare.
We are getting the documents from customer's gmail inbox folder.
Also we are using DocuWare Cloud.
Tiago
Ottieni aiuto
Cerca nella Knowledge Base
Chiedi alla community
Nuova richiesta di assistenza
