Registrato Thu, 06 Jan 2022 15:28:07 GMT di Steve Shriver Application Specialist
I have uploaded a text file of Vendor Names as a filter to an intelligent Indexing field according to the instructions. The Invoice image used has the vendor name 3D Diagnostix, Inc. The entry in the filter file has the entry 3D Diagnostix Inc. A subtle difference to be sure (no comma), but this is required due to the strict rules of the accounting application that the data will be imported to after processing.
After repeated attempts using a new copy of the image each time, Intelligent Indexing always chooses the name used on the image. Should I expect DW to substitute the entry in the filter file, or am I misunderstanding the filter file's purpose.
Any clues appreciated.
Registrato Fri, 14 Jan 2022 00:00:16 GMT di Matthias Wieland Senior Director Support EMEA
Dear Steve Shriver! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-168324-G7T4Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
