Registrato Tue, 19 Nov 2019 16:05:12 GMT di Casey Miller Director of Technical Services
is there any documentation on using Docuware desktop apps in a Citrix environment? Not seeing anything on the KB. See some old information but pertaining to Version 7 and above.
Registrato Tue, 19 Nov 2019 16:07:35 GMT di Casey Miller Director of Technical Services
some users use connect to outlook but others don't use it. Is there a way to only have C2O installed on certain users image?
Registrato Tue, 19 Nov 2019 17:05:44 GMT di Josef Zayats
Casey,
we found that the only way to prevent some Citrix users from using C2O connection is to uncheck their C2O setting  'Login at Start'. If the user action to uncheck manually is not acceptable, then setting can be changed programmaticly in a  C2O configuration xml file located in %userprofile%\AppData\Roaming\Docuware\Connect to Outlook\ folder.
This way only some Citrix users will have C2O connected.
