Registrato Fri, 20 Sep 2019 14:53:29 GMT di Casey Miller Director of Technical Services
Are there any good details on performing a server migration with Docuware 7? I know there is already a post about this but the instructions given only work if you are using MSSQL not MySQL. The instructions want you to install version 7 on new server then restore the backup to the new DB and then uninstall Docuware. But if you uninstall it gets rid of MySQL info. What is the procedure if using MySQL??
Registrato Fri, 20 Sep 2019 14:54:29 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Casey Miller! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-76509-K9D0Y for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
Registrato Thu, 14 Oct 2021 16:14:21 GMT di Marcin Kratiuk
We have a solution which can migrate the DocuWare configuration and documents between different DocuWare versions (including cloud and onpremise servers).  This is two step process. First we migrate the configuration. In the second step we migrate documents.
Please have a look here:
Power Copy for DW
Please do not hesitate to contact me in case of any questions
Thank You
Marcin Kratiuk
