Registrato Tue, 02 Apr 2019 16:38:46 GMT di Steve Shriver Application Specialist
I used this - IN ('value1','Value2','Value3') - using the Is(where clause) option for a field rule when creating a list in a DW Cloud system. The client throws a string parsing error when I try to open the list. I have used this successfully back in the admin tool days. Can anyone say what the correct way would be?
Many thanks,
Registrato Tue, 02 Apr 2019 17:51:41 GMT di Josef Zayats
Steve,
use the following syntax (OR must be in capitals).
Value1 OR Value2 OR Value3
