Registrato Fri, 25 Jan 2019 19:53:48 GMT di Michael Weingand Professional Services Manager
I can not seam to find how to create a true input field mask.  Like creating a Single Line text field and assigning it to telephone number then having the user just have to type the 10 digits for a US number and the dashes are forced.  Example  :510-963-9874 The mask is created as only a validation that the user puts in the dashes not having the field as a true mask.   nnn-nnn-nnnn.
Has anyone figure this out.  Or is this a missing feature since the new forms?
Registrato Fri, 25 Jan 2019 19:56:55 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
DocuWare Web Client does not automatically add any static characters such as hyphens for phone numbers or SSN's. The user must type the format. DocuWare simply validates the input.
Registrato Thu, 05 Dec 2024 14:12:21 GMT di Dennis Martinek
Phil, any chance this has changed yet? It is kind of a big deal if someone has to enter multiple phone numbers, SSN, etc.
Speaking of which, is there no way, when entering an SSN, that once typed, it can hide the numbers as you go with an asterisk?
What if someone starts a form, fills out the SSN, gets a cup of coffee, and someone walks by and sees it? And on the receiving end, can it be masked to show only the last four numbers for security reasons?
When dashes are not manually added, it's not like the box flashes red. Yeah, I could add a comment, please add dashes, but in this day and age, that seems to be the norm with most forms I've come across.
Thank you!
