Registrato Fri, 28 Sep 2018 14:09:23 GMT di Kim Sims Technical Solution Architect
I have a newly migrated F2DW client that is asking for a configuration change that will:
The autoindexing needs to show date modified, created by, indexed date, etc. in the search fields, not just in the right click fields. That needs to populate automatically and be in the search fields. Right now, they aren’t searchable.
Is it possible to expose the system fields so they are viewable via search and results dialogs?
Registrato Fri, 28 Sep 2018 15:14:07 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Hi Kim!
I asked this one a while back:
https://www.docuware.com/forum/english-forums/docuware-questions-about-usage-and-configuration/searching-system-fields-web-client
Basically, you add a field to the file cabinet that exposes the system fields beneath, and then you can decide what dialogs to display those new fields on.
Hope this helps!
