Registrato Tue, 23 Apr 2019 11:29:00 GMT di Neeskens Facciol
We have Docuware (7.0.0.8606) with Docuware Import Only Licence (not with Intelligent Indexing and Forms licence).
When configuring the Document Processing for Folder and Scanner the Indexing in the Processing Tab is disabled.
On the source tab the checkbox Disable text and barcode recognition is unticked.
When source is Printer indexing in the Processing Tab is enabled.
How do we active the indexing for Import from Folder and Scanner ?
Neeskens
Registrato Tue, 23 Apr 2019 12:26:15 GMT di Josef Zayats
Neeskens,
check the KB article at the link below.
For all the above-mentioned functionality you'd need to purchase an additional Docuware module, "barcodes and forms"
https://support.docuware.com/en-us/knowledgebase/article/KBA-35711
