Registrato Wed, 16 Jan 2019 17:28:52 GMT di Josef Zayats
Does anyone know if using NodeJS Validation with Store dialog used in Docwuare form submission, produces the same result as using the store dialog, In other words would it pass the error mewssage to the submitter of the form? What if public user is used to submit the form?
Registrato Wed, 16 Jan 2019 19:22:56 GMT di Casey Miller Director of Technical Services
Josef, I tested this and it does use the validation that you have for that store dialog.
https://www.docuware.com/sites/default/files/forums-images/validation_test_form.png
Registrato Wed, 16 Jan 2019 19:42:04 GMT di Josef Zayats
Casey,
thank you very much for going out of your way for testing this.
