Registrato Wed, 26 Jan 2022 12:13:45 GMT di Mayra Rossi
there is the possibility to show relation between multiple documents (1-N) and (N-1)?
For example:
Cabinet A has text field X that contain "10004,10340,10005"
Cabinet B has text field Y that contain "10340"
From cabinet A to B works with Contains operation.
From cabinet B to A don't works, because there isn't possibility to use it's contained operation.
How can we solve that?
Registrato Thu, 03 Feb 2022 00:00:10 GMT di Matthias Wieland Senior Director Support EMEA
Dear Mayra Rossi! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-169803-D4J9M for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Mon, 05 Dec 2022 14:44:40 GMT di Frederic Lambrecht TCEM Toshiba Région Centre Est Méditerranée Consultant systèmes
Hello.
I have the same problem. Did you find a solution?
Frédéric
Registrato Fri, 09 Dec 2022 16:26:17 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Frédéric Lambrecht,
this would be possible if one of the fields is a keyword field.
Registrato Thu, 09 Mar 2023 07:37:04 GMT di Mayra Rossi
No solution at the moment.<br> @Tobias, can't work with a keyword field either.. I tried.<br> <br> Regards&#160;<br> Mayra
Registrato Fri, 14 Apr 2023 09:35:59 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Mayra Rossi, Frederic Lambrecht,<br> <br> sorry for the late answer and for beeing not precise enough.<br> <br> One of the text fields has to be a keyword field. And it should be the field, which could contain multiple entries.<br> If you use a keyword field, than the different entries&#160;&quot;10004,10340,10005&quot; need to be as single entries in the keyword field. This means, that you might need to change, how the documents are stored<br> <br> Regards<br> Tobias Getz<br> Team Leader Product Management<br> DocuWare GmbH
