Registrato Fri, 18 Jun 2021 10:04:22 GMT di Rhys Woolley Software Developer
To put it simply, I've never worked on a workflow using merge forms. I've set the start condition to merge forms but nothing is appearing in the drop down lists. Does anybody have some documentation links they can share or some tips?
Thanks.
Registrato Fri, 18 Jun 2021 12:05:42 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Rhys,
did you select the fillable PDF?
Registrato Fri, 18 Jun 2021 13:24:23 GMT di Rhys Woolley Software Developer
I hadn't, but now I have and it works. Thanks
