Registrato Thu, 25 Jan 2024 15:46:40 GMT di Gilles Sauvagnat Altexence
Hi
Does anybody know if DocuWare OnPremise is able to run on Nutanux platform ?
If yes, limitation ?
Thanks in advance
Best regards
Gilles Sauvagnat
Registrato Thu, 25 Jan 2024 16:18:07 GMT di Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Gilles,
as far as I know, installing DW onPrem in private cloud environments is officially not supported.
Regarding Azure and AWS, I received an official statement from DW Support Team - it might work on the platform, but it is not supported by DocuWare.
Personally, I have one customer using onPrem on a single AWS Server, which currently works fine (7.9). I suppose issues with MSMQ will occur if you split the system on multiple Servers, which is probably the reason why it is not supported.
Registrato Thu, 25 Jan 2024 19:06:26 GMT di Gilles Sauvagnat Altexence
Hi Simon,
Thanks a lot for your feedback. We will create a SR to get the "official" statement
I agree, MSMQ is probably the mail risk as it is usually not supported or not working on such environnement
Best regards
Gilles
