Registrato Thu, 15 May 2025 12:49:41 GMT di Sander Helfensteijn
I have a order with several packingslip numbers on the document (various every order). I would like to have every packingslipnumber after the word "Packingslip"
I'm using document processing to index the full document. There is also a QR on the header but that doesn't have the packingslipnumbers.
All those numbers i want in a keyword field.
Can I do this using Autoindex/workflow?
OCR should have scanned the full document so the data is somewhere.
Registrato Fri, 23 May 2025 00:00:16 GMT di Matthias Wieland Senior Director Support EMEA
Dear Sander Helfensteijn! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-262918-D7Z7C for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
