Registrato Mon, 23 Apr 2018 17:04:54 GMT di David Dunton Software Solutions Engineer
Looking to "Configure a List" where date=previous calendar month. IE, if the current month is June, then display May results.
Is this possible? The "Within the past" is a number of days if i choose month, thus showing the wrong results.
I've played with the "Is (Where Clause)", without any luck.
This is for a cloud system, so SQL Statements are out of reach.
Registrato Mon, 23 Apr 2018 17:14:00 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
David,
I have not tested this but MSSQL supports DATEADD. So look to do something like this:
All before this month:
DATE <= DATEADD(month,-1,GETDATE())
Only last month:
(DATE >= DATEADD(month,-2,GETDATE()) AND DATE <= DATEADD(month,-1,GETDATE()))
Registrato Mon, 23 Apr 2018 17:26:52 GMT di David Dunton Software Solutions Engineer
Thank you for the quick reply.
I tried both of those, recieved a "Wrong condition!" error.
https://www.docuware.com/sites/default/files/forums-images/2018-04-23%2013_25_38-DocuWare.png
https://www.docuware.com/sites/default/files/forums-images/2018-04-23%2013_26_06-Configurations.png
Registrato Mon, 23 Apr 2018 17:59:29 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
David,
It would appear the the IS(WHERE...) clause does not support trancact SQL. I was able to execute a query as I indicated, but I used the SQL Query option, which is not supported for the Cloud.
Your clause is not quite right. Remove the word DATE at the start. Moot point though because it still won't work.
Sorry. But I don't have a solution right now. I'll give it some more thought.
Registrato Mon, 23 Apr 2018 18:15:41 GMT di David Dunton Software Solutions Engineer
Thanks Phil, i'll keep trying.
Registrato Mon, 23 Apr 2018 18:30:00 GMT di Josef Zayats
David,
I think your best bet to use t-sql in Docuware Cloud is AutoIndex workflow - these support SQL syntax with your FC table fields (not system fields though). So you can run an AI workflow that sets an additional field to a value that you could use in your Tasklist selection. Works for me.
Registrato Mon, 23 Apr 2018 18:34:11 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
David,
Good idea from Josef. If you do, replace GETDATE() with CURRENTDATE() that is what I used with my test.
Registrato Tue, 24 Apr 2018 18:23:19 GMT di David Dunton Software Solutions Engineer
https://www.docuware.com/forum/english-forums/docuware-help-technical-pr...
Looks like Free SQL Statements aren't available in Cloud, unless i'm missing something.
Thanks.
Registrato Tue, 24 Apr 2018 23:54:04 GMT di Josef Zayats
David,
Look at the Cloud AutoindexJob configuration - external database filter allows for SQL statement. - see the screenshot. The sql statement can reference your file cabinet tables and use any valid sql syntax and functions including DATEADD. I could not find a way to use system dields like DWSTOREDATETIME here, but this can be overcome by using custom fields that automatically aquire system fileds values.
https://www.docuware.com/sites/default/files/forums-images/2018-04-24_2055.png
Registrato Wed, 25 Apr 2018 14:23:12 GMT di David Dunton Software Solutions Engineer
Thats what I needed! Thanks to both of you.
I have one autoindex to set the value and another to remove it.
Tested and working.
SELECT
      DWDOCID
FROM BOOKINGDEALS
WHERE DATEPART(m, ContractDate) = DATEPART(m, CAST(GETDATE()AS Date)) -1
      AND DATEPART(yyyy, ContractDate) = DATEPART(yyyy, (DATEADD(m, -1, GETDATE())))
SELECT
      DWDOCID
FROM BOOKINGDEALS
WHERE DATEPART(m, ContractDate) = DATEPART(m, CAST(GETDATE()AS Date)) -2
      AND DATEPART(yyyy, ContractDate) = DATEPART(yyyy, (DATEADD(m, -2, GETDATE())))
      AND Status = 'PREVIOUSMONTH'
