Registrato Tue, 17 Apr 2018 13:44:29 GMT di Steve Shriver Application Specialist
A customer is using a large Select List based on a text file. After updating the text file and re-importing the select list, some entries, (that are confirmed as being part of the list using the preview function in the admin tool) do not appear as suggestions as the entry is being entered in to the index field. Entries preceding these do show up. Is there a limit on how many entries are returned? If so can the limit be modified?
Registrato Tue, 17 Apr 2018 13:49:48 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Steve,
See this FAQ:
https://www.docuware.com/support_faq/index.php?action=artikel&cat=173&id=1907&artlang=en&highlight=select+list
