Registrato Tue, 17 Apr 2018 13:38:33 GMT di Craig Heintz SE
I go another question about the SQL database for high availability.
Does DocuWare support SQL Clustering and/or ALWAYS ON configuration?
Registrato Tue, 17 Apr 2018 13:47:02 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
When creating an SQL cluster a virtual server is created. It is the virtual server that is addressed by applications such as DocuWare. In this way it appears to the clients as a single server even there may be many in the cluster.
