Registrato Fri, 19 Mar 2021 10:46:50 GMT di Dean Birks ABC Digital Solutions LTD Professional services
HI,
I've set up a check for duplicates work flow using the knowledge base KBA-36363
But when we test the workflow it states some_string,Some_String_1,Some_String_2 ( see pic attached) no matter if its a duplicate PONumber or not. So i cant get it to say its not a duplicate.
Any help appreciated.
Dean
Registrato Fri, 19 Mar 2021 14:25:26 GMT di Stefan Kinitz Datatronic Software AG DSC
Hi Dean,
the test function in the workflow designer does not work.
You have to publish your workflow and test it in the web client.
Registrato Mon, 22 Mar 2021 13:35:59 GMT di Dean Birks ABC Digital Solutions LTD Professional services
Thanks. Yes it was just that the test doesn't work.
Thanks for the help
Dean
