Registrato Thu, 06 Dec 2018 08:22:51 GMT di Jean Wochner Pre Sale Specialist
We are looking to use Power BI to create a reporting tool for DocuWare.
Is anyone in the forum aware of an existing Power BI <> DocuWare connector already developed?
Thank you in advance.
Registrato Fri, 07 Dec 2018 03:47:19 GMT di Fabrice Mosca
I don't use Power BI, but I have found Metabase (metabase.com).
That's a very powerful BI tool. I use the REST API to extract the datas I need and store them in a sqlite database with a python script.
Metabase read this database and display my Dashboard.
Registrato Fri, 07 Dec 2018 08:46:52 GMT di Tim Koehler
Depending on the Database Type you use for DocuWare you could directly access the dwdata-database via ODBC or Microsofts bulit-in Database Connector within PowerBI and create your reports using that data. You'd need to select every file cabinet without the underscore suffix.
Registrato Fri, 07 Dec 2018 12:50:50 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Power BI supports just about every data source under the sun, though of course that will only work if you have DocuWare installed in-premise. If you are attempting to access cloud data, then the Platform Service route may be your only play.
Registrato Thu, 02 Jun 2022 09:42:06 GMT di David Bürscher
If you are interested in Power BI dashboards for docuware, please feel free to contact us:<br> <br> <a href="https://app.powerbi.com/view?r=eyJrIjoiNGU3YWJkNzMtYTg5My00ZTA1LTg5NDktYTBjOWExNTAyNmFkIiwidCI6IjIyOGY5ZTI0LTRlMTAtNGIwNS1hNmY3LWMyYTgxMWIzZTYyZSIsImMiOjh9">DocuWare - Power BI Dashboard</a><br> <br> <a href="https://www.admin-iq.at/dashboards-rechnungsverarbeitung/" rel="nofollow noreferrer">https://www.admin-iq.at/dashboards-rechnungsverarbeitung/</a><br> <br> &nbsp;
Registrato Thu, 20 Jun 2024 19:25:07 GMT di Pedro E. Gonzalez-Santini Gm
Hello, Jean.  Admin IQ looks good. There is also this solution presented at DocuWorld Americas 2024: https://weareintuitive.com/process-management/intuitive-for-docuware/
The contact person in USA is jodi.lindner@ecoprintq.com
Regards.
