Toggle navigation
Forum
Knowledge Base
Stato
Download
Richieste di supporto
Tutto
Tutto
Pagine Web
Forum
Articoli della Knowledge Base
Filtro di Ricerca
Tutto
Pagine Web
Forum
Trova risposte
Italiano
Deutsch
Español
Français
English
日本語
Italiano
Accedi
Home
Forum della comunità
Questions about usage and configuration
IBM Informix database connection ODBC
Registrato
Sun, 15 Oct 2023 08:58:09 GMT
di
Mohamed Saidani
SG Software
ECM IT Manager
hi,
Is the connection to the Informix database via ODBC possible with DocuWare 7?
Registrato
Mon, 16 Oct 2023 06:31:04 GMT
di
Alexander Weber
Application Management
Hi, yes we also use an Informix ODBC connection and it works.
Registrato
Mon, 16 Oct 2023 07:06:27 GMT
di
Mohamed Saidani
SG Software
ECM IT Manager
Thank you for confirmation. Are you using a 64bit or 32 odbc driver?
Registrato
Mon, 16 Oct 2023 13:41:49 GMT
di
Tyler Smith
Technician Software Support
Up to DocuWare 6.12, we used 32 bit ODBC data sources. With Versions 7+, we use 64 bit data sources.
Registrato
Mon, 16 Oct 2023 14:07:00 GMT
di
Mohamed Saidani
SG Software
ECM IT Manager
For me, 64 bit odbc does not appear in DocuWare Administration because it's 32 bit. can you send me the procedure used?
Thank you so much!
Ottieni aiuto
Cerca nella Knowledge Base
Chiedi alla community
Nuova richiesta di assistenza
