Publicado Sun, 15 Oct 2023 08:58:09 GMT por Mohamed Saidani SG Software ECM IT Manager
hi,
Is the connection to the Informix database via ODBC possible with DocuWare 7?
Publicado Mon, 16 Oct 2023 06:31:04 GMT por Alexander Weber Application Management
Hi, yes we also use an Informix ODBC connection and it works.
Publicado Mon, 16 Oct 2023 07:06:27 GMT por Mohamed Saidani SG Software ECM IT Manager
Thank you for confirmation.  Are you using a 64bit or 32 odbc driver?
Publicado Mon, 16 Oct 2023 13:41:49 GMT por Tyler Smith Technician Software Support
Up to DocuWare 6.12, we used 32 bit ODBC data sources. With Versions 7+, we use 64 bit data sources.
Publicado Mon, 16 Oct 2023 14:07:00 GMT por Mohamed Saidani SG Software ECM IT Manager
For me, 64 bit odbc does not appear in DocuWare Administration because it's 32 bit. can you send me the procedure used?
Thank you so much!
