Registrato Thu, 18 Aug 2022 13:41:15 GMT di Andreas Moroder CIO
I would like to implement this in a Docuware 7.2.0 Workflow
- show a Field where the user can insert a Text
- send this Text as Mail and the document as attachment
- the Server should send the mail, this to guarantee that the mail was sent.
- the sending of the mail should also be logged in docuware
Is this possible?
If docuware downloads the document to the client to send it from there, the user could simply not send the mail ( mistake,malice)
Greetings
Andreas
Registrato Fri, 26 Aug 2022 00:00:16 GMT di Matthias Wieland Senior Director Support EMEA
Dear Andreas Moroder! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-184466-H6V9S for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Registrato Wed, 31 Aug 2022 09:36:27 GMT di Ute Degen Sr. Specialist Software Support Team GREEN EMEA
It is possible to do this with a workflow in DocuWare 7.2, you would need a task activity and after this an email activity.
In the Task you need a Dialog (this is where the user can fill in the email body), this then needs to be assigned to a global variable. (It is also possible to add other fields here, such as the recipient or the subject).
Then these variables can be added to an email activity (please be aware that it is currently not possible to add line breaks in a text field, therefore everything within a variable will be displayed in one line). Here you can also decide whether the document is to be sent along as well.
As for documenting the emails, if the workflow runs into an error sending an email it will create a general error task with an error message for the workflow controller (it is also possible to connect the error exit to another task / other steps that the workflow will do if it runs into an error), this as well as if the email was sent successfully is all documented in the documents' history.
Best regards,
Ute Degen
Technician Software Support Team GREEN EMEA
