Registrato Mon, 08 Jan 2018 15:30:09 GMT di Jacek Musiał
I have a little problem with docuware... i have 100 % disk space usage, how can i remove old documents ?
Thank you for your help.
Regards.
Jacek.
https://www.docuware.com/sites/default/files/forums-images/documents.PNG
Registrato Mon, 08 Jan 2018 15:34:59 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
You can run a Deletion Workflow. This will allow you to delete documents based on a date range. Do you really want to do this? Can you not add extra disk space? Once deleted those documents are gone forever.
Registrato Mon, 08 Jan 2018 16:00:55 GMT di Jacek Musiał
Yes, i know and i want to do this :-)
Can you give me instruction how can i do it  ?
Registrato Mon, 08 Jan 2018 18:02:45 GMT di Jacek Musiał
I had 18,281 documents and i removed 1000 documents and still have 18,281 ?
I don't understand why ?
Registrato Mon, 08 Jan 2018 18:06:48 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
How did you remove 1000 documents? Did you run a deletion workflow?
At this point I suggest that you open a Support Request so that we can assist you.
Registrato Mon, 08 Jan 2018 18:10:49 GMT di Jacek Musiał
I ran this task :
https://www.docuware.com/sites/default/files/forums-images/Capture_11.PNG
Registrato Mon, 08 Jan 2018 18:39:27 GMT di Jacek Musiał
Support request opened
Registrato Thu, 11 Jan 2018 08:21:43 GMT di Lukasz Luczak DevOps Engineer
Cześć Jacek
A co ustawiłeś w opcjach kasowania w Deletion Workflows - only documents czy documents and index data?
Pozdrawiam
Łukasz
