Registrato Thu, 09 Aug 2018 12:08:05 GMT di Seth Jaco Support Specialist
I have recently been digging into the API using .NET and was wondering if there was a way to create a data record from data inside a CSV or XML file? I am able to store data + documents using the API but now I need to know if I can just store data.
Seth
Registrato Thu, 09 Aug 2018 12:52:27 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Seth,
In between you contacting me on LinkedIn and posting this, I figured it out!
Here is sample C# code to post just store data to a file cabinet:
Organization org = <reference to your organization instance from the ServiceConnection>
string cabID = lvFileCabinets.SelectedItems[0].SubItems[1].Text;
FileCabinet fileCabinet = org.GetFileCabinetById(cabID);
Document indexInfo = new Document();
indexInfo.Fields = new List<DocumentIndexField>();
indexInfo.Fields.Add(DocumentIndexField.Create("INDEXFIELD1", <index value>));
indexInfo.Fields.Add(DocumentIndexField.Create("INDEXFIELD2", <index value>));
Document uploadedDoc = fileCabinet.PostToDocumentsRelationForDocument(indexInfo);
The crucial method here is "PostToDocumentsRelationForDocument". That lets you post just index data and creates a data-onle document for you in the cabinet.
You would need to take your CSV of XML file to load up the index info document, but that should be doable in C#, too.
Good luck, hope this helps!
Registrato Thu, 09 Aug 2018 13:08:00 GMT di Seth Jaco Support Specialist
That is awesome, I was close but did not get the Post command correct. I will post what I have when I get it working.
Seth
EDIT: Well l was finally able to work on this for a bit and am not able to get "PostToDocumentsRelationForDocument" it is stating there is no definition for it. Digging around and will see what I can find.
Registrato Thu, 09 Aug 2018 18:24:00 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Seth,
That is a method of a FileCabinet object. If it is not displaying in Intellisense then you aren't performing the method call on a FileCabinet object. There is really no way C# code can be wrong, because it won't compile if the objects are not of the right type. Can you post some code?
Registrato Thu, 09 Aug 2018 18:54:29 GMT di Seth Jaco Support Specialist
Sure, what I have so far is a Windows form that uses a test name and password to make my connection. It then has a drop down box that populates on form load to show the available file cabinet
 var conn = ServiceConnection.Create(uri, "BasicAdmin", "admin", "TestSrv");
            Organization org = conn.Organizations[0];
            var fileCabinet = org.GetFileCabinetsFromFilecabinetsRelation().FileCabinet;
            foreach (var fc in fileCabinet)
                fCabinet.Items.Add(fc.Name);
I then have a button that processes a CSV file and hopefully will insert the data to create a data record
//Path for the CSV file.
                string csvPath = @"C:\Test.csv";
                //Read the contents of CSV file.
                string csvData = File.ReadAllText(csvPath);
                //Execute a loop over the rows.
                foreach (string row in csvData.Split('\n'))
                    //Creating array to read CSV into.
                    string[] cell = null;
                    if (!string.IsNullOrEmpty(row))
                        cell = row.Split(',');
                        int docID = Int32.Parse(cell[0]);
                        indexInfo.Fields.Add(DocumentIndexField.Create("Contact", cell[1]));
                        indexInfo.Fields.Add(DocumentIndexField.Create("Subject", cell[2]));
                        Document uploadedDoc = fileCabinet.PostToDocumentsRelationForDocuments(indexInfo);
I hope that makes sense.
Registrato Thu, 09 Aug 2018 19:05:25 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Seth,
In your button's click event, you cannot just reference "fileCabinet" if that variable is not in the Click event code. This is a "scope" issue. Each subroutine can only see the variables declared within it. So, unless you make "fileCabinet" a form-level member or property (that everything inside the form class can see), it will never generate any Intellisense and things will not compile. There is likely a red squiggly line under it because the design-time editor is saying, "I have no iidea what fileCabinet is in this context."
How do you display a list of available file cabinets? In other words, how does the List<string> called "fCabinet" manifest itself so you can select an actual file cabinet? Where do you load the names, and how do they display? If you just load those names in a List in one method, they are not going to be available to any other method. You need a form-level member that is a list of file cabinet GUIDs or something you can select/reference to choose the file cabinet to use. Alternately, you need a control on the form such as a ListView, as controls on the form can be references anywhere on the form since they are UI-related member classes of the form.
Once you have a real, instantiated FileCabinet object in that routine, the appropriate method will be available for it and you will be in business.
Registrato Thu, 09 Aug 2018 19:19:39 GMT di Seth Jaco Support Specialist
Gotcha, I am writing the File Cabinets to a Combox Box using the last line under the first section of code "fCabinet.Items.Add(fc.Name);"
It displays quite well
https://www.docuware.com/sites/default/files/forums-images/DropDown.JPG
Registrato Thu, 09 Aug 2018 19:48:28 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Seth,
Nice. You will want to store the file cabinet GUID in the combo box, too (hidden column?) or use a ListView that can have multiple columns. Then, in the button click, check the index of the combo box and get the GUID. Then you should be ready to go.
I will be around more tomorrow but am off work all weekend and next week, so hopefully you get this working by then!  *smile*
Registrato Tue, 14 Aug 2018 19:36:36 GMT di Seth Jaco Support Specialist
I was able to work on this a bit today, however, I am getting an error message "Cannot implicitly convert type String to DocuWare.Platform.ServerClient.FileCabinet. Any thoughts?
Registrato Wed, 15 Aug 2018 11:31:49 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Seth,
When you have these errors, you need to provide the code that is erroring out. There is no way to debug without seeing the line that is erroring out and the lines around it. Also, is this a compile-time or run-time error?
I am on vacation until Monday, so if you provide a sample by then I can take a look. It sounds like you are simply supplying the wrong data type to a field as you are creating the indexes for the store. Make sure all data types match what the DocuWare cabinet is expecting.
Registrato Wed, 15 Aug 2018 11:37:26 GMT di Joe Kaufman Bell Laboratories Inc No longer there
It also sounds like you are trying to use a string variable as a FileCabinet type, so your code seems to have some fairly serious issues...
Registrato Wed, 15 Aug 2018 13:51:27 GMT di Seth Jaco Support Specialist
No worries, I remember having this issues before and I cannot for the life of me remember what I did to resolve it. Here is the code that it does not like. I am taking the highlighted option, from the Listview and trying to pass it through for use of the stored document. So the user selects a File Cabinet, then when they hit a button it should store the data in the CSV file as a new data store for that File Cabinet that was selected. The error is occuring on the starred line for cabID
string cabID = (fCabinet.SelectedItems)["File Cabinet"].ToString();
*FileCabinet fileCabinet = cabID;*
Registrato Thu, 16 Aug 2018 12:06:07 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Seth,
You are trying to assign a string directly to a FileCabinet type. That's not going to work. A FileCabinet instance needs to be created with the "new" keyword, as in:
FileCabinet cab = new FileCabinet();
I am not sure if the constructor of FileCabinet can take a GUID string directly, but I am pretty sure it cannot. I think a file cabinet is created from an Organization object, but do not have my sample code handy until Monday.
Registrato Mon, 20 Aug 2018 12:41:52 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Seth,
OK, I got some sample code, and I realize getting a specific file cabinet is not as easy as I thought -- I wrote some extension methods to make it easier.
Here is an extension method of an Organization object that can get you a file cabinet by it's ID:
public static FileCabinet GetFileCabinetById(this Organization org, string fileCabinetId)
    FileCabinet fileCabinet = null;
    if (org == null) return null;
    if (fileCabinetId.Length == 0) return null;
    List<FileCabinet> fileCabinets = org.GetFileCabinetsFromFilecabinetsRelation().FileCabinet;
    fileCabinet = fileCabinets.Where(f => f.Id.Trim().ToUpper() == fileCabinetId.Trim().ToUpper()).First();
    return fileCabinet;
Basically, if you put the above static method somewhere in scope (same namespace), then Intellisense will offer the method as an extension method of the Organization object. It would appear the key method built in to DocuWare is GetFileCabinetsFromFilecabinetsRelation(), but that returns all file cabinets. So, we filter the List of FileCabinet objects using LINQ. Here is the same thing, but it gets a file cabinet by name instead of GUID:
public static FileCabinet GetFileCabinetByName(this Organization org, string fileCabinetName)
    if (fileCabinetName.Length == 0) return null;
    fileCabinet = fileCabinets.Where(f => f.Name.Trim().ToUpper() == fileCabinetName.Trim().ToUpper()).First();
    return fileCabinet;
I am not sure why DocuWare does not build in these handy methods to the package libraries, or maybe there is a better way and I just don't know it. Here is the help page on getting file cabinets, so I must have gotten my original code/idea from there:
http://help.docuware.com/sdk/platform/html/ee25973f-3c6a-456b-967d-a8b179881d3f.htm
Hope this helps!
Registrato Mon, 20 Aug 2018 13:43:49 GMT di Seth Jaco Support Specialist
Awesome, hopefully I can get some time later this afternoon and test. I will let you know what I find.
Registrato Mon, 20 Aug 2018 13:47:59 GMT di Joe Kaufman Bell Laboratories Inc No longer there
Here is a quick link to implementing extension methods in general:
https://docs.microsoft.com/en-us/dotnet/csharp/programming-guide/classes-and-structs/extension-methods
