Registrato Thu, 03 Oct 2019 15:21:03 GMT di Céline Verjans
How do you set up the configuration to the physical printer in the office?
More specifically, if I use the DocuWare printer, I want my documents to be printed in the office aswell.
Registrato Thu, 03 Oct 2019 15:22:03 GMT di Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Céline Verjans! It looks like the Community cannot answer your question. Thats why we have opened a Support Request with the Number SR-111431-D1X0G for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have solved the Support Request. With Best Regards, DocuWare Support Team
Registrato Tue, 22 Oct 2019 08:02:56 GMT di Patrick Kollar Software Support Specialist Team BLUE EMEA
Dear Mrs. Verjans,
this option is available in the "Target"-Section in the DocuWare Printer configuration.
Just tick the "Send copy to printer" tickbox, then you should be able to choose the hardware Printer you want to use.
I also attached a screenshot for a better understanding.
Thank you.
With best regards,
Patrick Kollar
Software Support Specialist Team PURPLE EMEA
