Registrato Fri, 05 Jan 2018 17:41:28 GMT di Chris McFarland Sr. Document Workflow Specialist
Hello, Everyone:
Changes to the Field order for me Result Lists don't seem to have any effect in the Client.
Field Order changes to other dialogs seem to work fine.
Any ideas on this one?
Thanks!
Registrato Thu, 11 Jan 2018 16:06:29 GMT di Josef Zayats
Chris,
most likely the user customized this particular reslult list (e.g. changed columns order) - then the changes to colum order made tn the Administration/Configuration will not show.
To clear the user custom settings see the following KB Article:
https://www.docuware.com/support_faq/index.php?action=artikel&cat=185&id...
