Registrato Thu, 04 Jan 2018 19:44:31 GMT di Craig Heintz SE
There is discussion of having a DocuWare Cloud account for the day to day operations and an on premise system for the long term archival storage.  I see that from the cloud admin tool I can do an Export Workflow to move documents to another system and cabinet and delete them in the cloud.
I expect that I would have to be able to securely access the on premise system from the web for authentication on port 9000.
What other ports would I need open to make this work?
Are there any drawbacks to this scenario?
Registrato Thu, 04 Jan 2018 19:54:37 GMT di Phil Robson DocuWare Corporation Senior Director Professional Services, Americas
Craig,
This is pretty well the scenario with our described hybrid system. Usually it is simply the other way round. Work On-Premise, archive to Cloud. But either way works. 9000 for Authentication, 80 and 443 communication. No drawbacks. I like the Export delete concept over synchronization. It will keep the Cloud disk usage down, hence the costs.
Registrato Thu, 04 Jan 2018 19:59:02 GMT di Craig Heintz SE
Excellent.  Thanks for the super quick response and confirmation.
