Registrato Thu, 05 Aug 2021 13:50:08 GMT di Steve Shriver Application Specialist
A Cloud system user has received a notification that the storage is now at 95% and will run out soon. I have seen the Status item in the Product Overview section and confirmed this.
However, in order to make a recommendation as to how much more storage the customer should obtain, I would need some more detailed statistics, such as number of documents/month or GB used per month, as an example.
Are there more detailed statistics about data usage in cloud systems available?
Registrato Fri, 06 Aug 2021 15:47:04 GMT di Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Steve,
open the notification center in DocuWare and click on Cloud Status. There are now three areas "Status", "Storage" and "Performance". The Stoprga earea is wher you can see the data about stored documents and storage space.
