Registrato Mon, 20 Jan 2020 16:39:45 GMT di Keith Telford App. Support
Since DW is only a one way sync from AD.
Is there a way to export the User Admin -> Users out of docuware ...I would like to compare the current active users in AD compared to the Users in Docuware ...we have over 400 users in Docuware so it is more than a quick search
Registrato Thu, 23 Jan 2020 15:07:09 GMT di Craig Heintz SE
If you can get to the database tables there is a table in DWSYSTEM db DWUSERS then you can do it.
Registrato Thu, 23 Jan 2020 15:41:48 GMT di Gerardo Lisanti Team Leader Product Management
Hi Keith,
you can try to get the users via the REST API and import them into e.g. Microsoft Office Excel
  • Login to DocuWare as Administrator
  • In a new tab open https:// ... /DocuWare/Platform/Organization/Users
  • Right click and Save as XML file
  • In Microsoft Office Excel import the XML file via Data > Get Data > From File > From XML
    see screenshot attached
Let me know if this helps.
Manager Product
