Dear Community,
Due to a technical limitation, parts of the full-text data and search are currently not fully available.
We apologize for the ongoing full-text search restrictions and past misleading communication you received. We want to provide you with an interim solution which can be implemented by yourself. I will result in an immediate fix to the full-text restriction.
We have already started the recreation (re-indexing) of the full-text catalog from our side. Depending on the size of the file cabinet and the number of documents, this may take some time and will be started in multiple waves. The status of the process can be checked by following point 6 of the article mentioned below.
If no re-indexing has been done for your system yet, you can start a re-indexing by following these instructions:
https://support.docuware.com/en-us/knowledgebase/article/KBA-36960
