投稿済み Thu, 18 Aug 2022 17:41:59 GMT 、投稿者 Hameed Ogbara Technical Support
How can Docuware take the font type from a word application.
We discovered that when a document was imported into the document tray the font type that was used in word was changed by Docuware. How can this be resolve so that Docuware picks or import document using the default font type of the application.
Thank you
投稿済み Fri, 26 Aug 2022 00:00:43 GMT 、投稿者 Matthias Wieland Senior Director Support EMEA
Dear Hameed Ogbara! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-184467-H9D5F for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
投稿済み Fri, 02 Sep 2022 06:00:00 GMT 、投稿者 Sebastian Krause Software Support Specialist Team RED EMEA
Dear Hameed Ogbara,
as a rule of thumb: If another font is displayed in the DocuWare Viewer, the font is not embedded to the document.
In order to enable the DocuWare Image workers to render the document with the correct font, the font needs to be installed on all DocuWare frontend machines.
Simply copy the font file (f.e. fontname.ttf) to the server and double click on it. The windows font viewer will open. In this font viewer you can install the font right away.
Windows Font Viewer
