Toggle navigation
ナレッジベース
クラウドステータス
アップデート
全て
全て
Web ページ
フォーラム
サポート情報記事
検索フィルター
全て
Web ページ
フォーラム
サポート情報記事
答えを見つける
日本語
Deutsch
Español
Français
English
日本語
Italiano
ホーム
コミュニティフォーラム
Help with technical problems
Upgrading to 7.2
Upgrading to 7.2
投稿済み
Fri, 06 Dec 2019 16:59:32 GMT
、投稿者
Bernie Svitko
We are upgrading form 6.12 to 7.2. On our test server, we upgraded from 6.12 to 7.0 then to 7.1. When upgrading to 7.2, the simulation gives us the error in the attached doc.
Any suggestions as to what might be causing the problem?
screen shot.rtf (4.8 MB)
投稿済み
Fri, 06 Dec 2019 17:56:19 GMT
、投稿者
Jon Weston
File IT Solutions
Sr Application Developer and RIM specialist
Hi Bernie,
I had this exact error when upgrading from 7.1 to 7.2 in October so I contacted support and they said this:
"This is a common issue with simulation's when the DB is on a different server. This could be an issue with the service credentials you've entered for the upgrade if it does not have permission to access, read, and write to the location where the backup is. Also, sometimes DB user mappings aren't always created for the simulation when the DB is external. They easiest way around this error is to ensure you have a complete DB backup and do not run the simulation. "
ヘルプを入手
ナレッジベースベースから検索する
