投稿済み Fri, 28 May 2021 17:04:49 GMT 、投稿者 Michael Weingand Professional Services Manager
I have a workflow that I am setting the Date and Time  when stamped.  It shows the date with the time as 12:00, Not the actual time.  I have the fields built as DATETIME in the database.  What am I missing?
投稿済み Fri, 04 Jun 2021 17:04:49 GMT 、投稿者 Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Michael Weingand! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-151666-P3K4X for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
投稿済み Wed, 16 Oct 2024 19:10:35 GMT 、投稿者 Jared Young IT Specialist
I had the same issue. The fix was to use an arithmetic expression and then just type 'NOW()' (without quotes).
Workflow variable CURRENT_DATE is just a DATE format. NOW() is a DATE/TIME format.
