Publicado Fri, 28 May 2021 17:04:49 GMT por Michael Weingand Professional Services Manager
I have a workflow that I am setting the Date and Time  when stamped.  It shows the date with the time as 12:00, Not the actual time.  I have the fields built as DATETIME in the database.  What am I missing?
Publicado Fri, 04 Jun 2021 17:04:49 GMT por Matthias Wieland DocuWare Europe GmbH Sr. Director Support EMEA
Dear Michael Weingand! It looks like the Community cannot answer your question. That's why we have opened a Support Request with the Number SR-151666-P3K4X for you. A Software Support Specialist will contact you directly to follow up. We will update this thread with the solution as soon as we have resolved the Support Request. With best regards, DocuWare Support Team
Publicado Wed, 16 Oct 2024 19:10:35 GMT por Jared Young IT Specialist
I had the same issue. The fix was to use an arithmetic expression and then just type 'NOW()' (without quotes).
Workflow variable CURRENT_DATE is just a DATE format. NOW() is a DATE/TIME format.
