Toggle navigation
ナレッジベース
クラウドステータス
アップデート
全て
全て
Web ページ
フォーラム
サポート情報記事
検索フィルター
全て
Web ページ
フォーラム
サポート情報記事
答えを見つける
日本語
Deutsch
Español
Français
English
日本語
Italiano
ホーム
コミュニティフォーラム
Questions about usage and configuration
AutoIndex jobs - move file to backup directory
投稿済み
Thu, 30 Jul 2020 00:25:49 GMT
、投稿者
Steve Shriver
Application Specialist
After upgrading to v7.3 it seems that AutoIndex jobs using a text file do not move do not move the file to the AIX Backup directory as configured previously.
Has anyone experienced this behavior or know if this is a bug in 7.3?
投稿済み
Thu, 30 Jul 2020 05:15:04 GMT
、投稿者
Gilles Sauvagnat
Altexence
Hi
If not done yet, you should have a look at BPS logs (\programdata\docuware\logs) and search for any error with autoindex job
You might encountered the error I had with an Autoindex jobs triggered on filecabinet event, there was a bug in 7.3
Gilles
投稿済み
Thu, 30 Jul 2020 13:00:22 GMT
、投稿者
Steve Shriver
Was a bug? Is there a HotFix or Minor Update to correct it?
投稿済み
Thu, 30 Jul 2020 13:57:08 GMT
、投稿者
Gilles Sauvagnat
Altexence
My SR was SR-127917-Q3T5F
The fix was to install the last 7.3 version (it was July 8th) and to modify the
DocuWare.BPS.Processes.settings in C:\Program Files\DocuWare\Background Process Service.
And set the SelfTriggeredAmountLimit. to 0
Then restart BPS.
BUT, i cannot guarantee our problem is the same as mine. My problem was thaht the autoindexailed to start and I found "format name buffer memory delivered by API too small to adjust to format name" in the log
I would recommend you to submit a SR if your case is different
Gilles
ヘルプを入手
ナレッジベースベースから検索する
