投稿済み Tue, 19 Feb 2019 18:10:38 GMT 、投稿者 Steve Shriver Application Specialist
I am trying to eliminate a trailing comma at the end of a string in a DW Printer template I have listed the 'old value' as ',' but trying to enter a space as the 'new value' does not seem to be recognized.
Any clues appreciated,
投稿済み Tue, 19 Feb 2019 18:35:36 GMT 、投稿者 Josef Zayats
Steve,
Replace Text option only works for whole string replacement.
If the srtring you're trying to edit is not supposed to have commas other than trailing, you can use option "Select Text" - "Before Known  character" - "," - From Beginning of text.
If commas (other than trailing) may be present within the string, you out of luck as far as the Printer configuration goes, and you'd have to use either SQL script or AutoIndex Job to remove trailing commas
