投稿済み Wed, 07 Feb 2024 12:55:11 GMT 、投稿者 Mélanie Mélanie
I found the way to disable the "Send request" button in Result dialogs and also for Lists but I am unable to find it for Folders.
Do you know if there is a way to hide this button for Folders or more globally for a file cabinet?
Thanks a lot,
Best regards.
投稿済み Wed, 07 Feb 2024 18:28:13 GMT 、投稿者 Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Mélanie,
this setting is always defined on a dialog level, it is not possible to set it on file cabinet level.
For folders, there is no way to disable it.
The setting is stored in the dwsystem database, however, disabling it manually in the database seems to have no effect.
I just tested this on DW 7.9.
投稿済み Thu, 08 Feb 2024 07:54:09 GMT 、投稿者 Mélanie Mélanie
Thanks for your quick answer. It's too bad that we can not disable it from folders because business users will make the mistake and use it...
Best regards,
