投稿済み Wed, 05 Jun 2024 17:29:45 GMT 、投稿者 Jon Sproule OE Canada Inc. Content Management Consultant
Hello community. I have a client that is using QuickBooks and is asking if we can use DocuWare to populate the memo filed within QuickBooks when the data is exported. Specifically, they want to combine two fields (the PO number, and the first column description) and have this populate the field. The end result would be 12345 - Inventory, for example. I suspect a workflow could be created to collate the appropriate text fields, but can this data then be part of the GL code data export? I realize this may not be as clear as intended, so please don't hesitate to ask for clarification. I appreciate any input you can share.
Thank you
投稿済み Mon, 10 Jun 2024 08:25:40 GMT 、投稿者 Tobias Getz DocuWare GmbH Team Leader Product Management
Hi Jon Sproule,
you are right, that a workflow could combine two fields into a new one. DocuWare Export can then be used to export the field values. I do not know, how to import this in Quickbooks as I do not have any Quickbooks knowledge, but from DocuWare this should be no issue to do.
DocuWare GmbH
投稿済み Mon, 10 Jun 2024 12:49:29 GMT 、投稿者 Jon Sproule OE Canada Inc. Content Management Consultant
Thank you, Tobias. I appreciate the response. I felt pretty confident about the workflow to combine data, now I just need to determine what can be exported to QuickBooks.
投稿済み Fri, 07 Feb 2025 08:25:59 GMT 、投稿者 Paolina Lee Document Control Manager
Hi all,
I’m also struggling with how to send data to QuickBooks via API or Make.com, as suggested by the DW team.
Are there any successful client cases we could refer to for setup guidance?
Thanks, community!
投稿済み Tue, 25 Feb 2025 22:41:02 GMT 、投稿者 Pedro E. Gonzalez-Santini Gm
Hello. Any new information about this?  In particular, how can AP Automation be accomplished? Make.com may have the necessary steps to send the data to QB.  https://www.make.com/en/integrations/quickbooks
There are 3rd party apps shown here https://quickbooks.intuit.com/app/apps/
We initially plan to export data in the csv format used by one of these apps. That app will then upload to QB but it is a manual batch process, not executed immediately.
