投稿済み Thu, 01 Jul 2021 12:15:41 GMT 、投稿者 Dirk Depoix Director Projects&Operations
I want to implement a specific release workflow. First step is, that sombody assings the release tasks to mulitple users. That can 1, 2 or 3, depending on the docuement.
All assigned users get a task. But currently the task is already finished, when only ONE of the users is answering (approved, rejected).
Is there a way, to collect all answers before the final task decsion is taken?
I tried to overcome this artihmetic function, but I failes to determine the number of assigned users.
Any hints?
Thanks.
投稿済み Thu, 01 Jul 2021 12:24:57 GMT 、投稿者 Martin Zebedies Uriot GmbH & Co. KG Head of Solution Consulting
Hi Dirk,
try the parallel task.
This one is waiting for an answer of every assigned user.
投稿済み Thu, 01 Jul 2021 13:27:20 GMT 、投稿者 David Rutt
Dirk,
How are you assigning the task to the users?  There are a few ways to do this.
投稿済み Thu, 01 Jul 2021 15:05:51 GMT 、投稿者 Dirk Depoix Director Projects&Operations
@Martin Zebedies: I thought I have to steer this with the cancel condition. Anyway I will give parallel tasks a try, thank you for the tip.
@David Rutt: in the first task (the "assignment task") a user selection list is presented. The selected users get the seceond task assigned.
Thanks.
投稿済み Thu, 01 Jul 2021 16:11:51 GMT 、投稿者 David Rutt
If you are selecting users in that manner, they will all get the same task.  If any one of them take action on it the task is completed.
Do the people that are being sent the task change at all?
投稿済み Tue, 06 Jul 2021 14:28:39 GMT 、投稿者 Dirk Depoix Director Projects&Operations
Sorry the late response. I implemented parallel task, but I need to test it with multiple users.
@David Rutt: the people getting the task assigned are changing, But once they are assigned to that specific task, they won't change anymore.
投稿済み Wed, 07 Jul 2021 13:39:55 GMT 、投稿者 Dirk Depoix Director Projects&Operations
Finally I made the testing. I had to implement certain changes to my workflow (eg. data assignments, status checks, had to be moved outside the task) but finally it works.
Thank you all for tipps and hints.
