投稿済み Wed, 12 Feb 2025 21:32:14 GMT 、投稿者 Daryl Foxhoven Sr. Systems Engineer
So we have a customer that wants to use DocuWare Forms for their Timesheets, however, I'm not seeing anyway to calculate time in forms (I'm sure I can do it in Workflow Designer)...in fact, I'm not even seeing a way other than a text field to enter any kind of time value?  Am I missing something?
投稿済み Thu, 13 Feb 2025 18:51:34 GMT 、投稿者 Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Daryl,
no, you are not missing anything. There is currently no time input in Forms.
Please check out uservoice and upvote the related posts.
My workaround is currently to use two decimal fields, one with min value 0, max value 23, the other with min 0, max 60.
I then build a normal time object using the workflow arithmetic expressions.
