Publicado Wed, 12 Feb 2025 21:32:14 GMT por Daryl Foxhoven Sr. Systems Engineer
So we have a customer that wants to use DocuWare Forms for their Timesheets, however, I'm not seeing anyway to calculate time in forms (I'm sure I can do it in Workflow Designer)...in fact, I'm not even seeing a way other than a text field to enter any kind of time value?  Am I missing something?
Publicado Thu, 13 Feb 2025 18:51:34 GMT por Simon H. Hellmann Toshiba Tec Germany Imaging Systems GmbH IT-Consultant Document Management Solutions
Hi Daryl,
no, you are not missing anything. There is currently no time input in Forms.
Please check out uservoice and upvote the related posts.
My workaround is currently to use two decimal fields, one with min value 0, max value 23, the other with min 0, max 60.
I then build a normal time object using the workflow arithmetic expressions.
