Toggle navigation
Foren
Knowledge Base
Status
Downloads
Supportanfragen
Alle
Alle
Webseiten
Foren
Knowledge Base Artikel
Suchfilter
Alle
Webseiten
Foren
Antworten finden
Deutsch
Deutsch
Español
Français
English
日本語
Italiano
Anmelden
Home
Community Foren
Help with technical problems
Can not create new Storage locations of configure File Connections in Docuware
Veröffentlicht
Sat, 28 Oct 2023 17:06:29 GMT
von
Panagiotis Basakidis
Software Solution Specialist
Dear all, I have setup a Docuware cloud system for testing purposes for our company. I have created a text file that contains "Document Type" and "SubType" fileds that I need to import to the system and connect to each other so when selecting a specific Document Type only some of the SubType fields will be available for the user. In order to do so I have to be able to configure single and multi column select lists that are configured through database connections. Now my issue is that although my user has full access rights in Docuware, when I open Docuware Administration I am not allowed to add any new storage locations and I can not configure the already existing one. The purpose is to import a .txt file in order to use two columns that will be matched with 2 Docuware index fileds. Could someone help with this issue. Thank you.
Docuware Administration Can not configure new Storage Location.jpg (180,7 KB)
Veröffentlicht
Mon, 30 Oct 2023 09:07:21 GMT
von
Toshiba Tec Germany Imaging Systems GmbH
IT-Consultant Document Management Solutions
Hello all,
this is a duplicate post of
Please continue discussion there.
Hilfe erhalten
Suche in Knowledge Base
Community fragen
Neue Supportanfrage
