Toggle navigation
Forums
Knowledge Base
Status
Downloads
Solicitudes de Supporte
Todos
Todos
Páginas web
Foros
Artículos de conocimientos
Search Filter
Todos
Páginas web
Foros
Encontrar respuestas
Español
Deutsch
Español
Français
English
日本語
Iniciar sesión
Home
Community Forums
Help with technical problems
Can not create new Storage locations of configure File Connections in Docuware
Publicado
Sat, 28 Oct 2023 17:06:29 GMT
por
Panagiotis Basakidis
Software Solution Specialist
Dear all, I have setup a Docuware cloud system for testing purposes for our company. I have created a text file that contains "Document Type" and "SubType" fileds that I need to import to the system and connect to each other so when selecting a specific Document Type only some of the SubType fields will be available for the user. In order to do so I have to be able to configure single and multi column select lists that are configured through database connections. Now my issue is that although my user has full access rights in Docuware, when I open Docuware Administration I am not allowed to add any new storage locations and I can not configure the already existing one. The purpose is to import a .txt file in order to use two columns that will be matched with 2 Docuware index fileds. Could someone help with this issue. Thank you.
Docuware Administration Can not configure new Storage Location.jpg (180,7 KB)
Publicado
Mon, 30 Oct 2023 09:07:21 GMT
por
Toshiba Tec Germany Imaging Systems GmbH
IT-Consultant Document Management Solutions
Hello all,
this is a duplicate post of
Please continue discussion there.
Obtenga ayuda
Buscar en Knowledge Base
Pregunte a la Community
Nueva solicitud de soporte
