Veröffentlicht Wed, 23 Jan 2019 23:09:06 GMT von BONNEAU Stephane CEO
Hello all,
Do somenone know how to confirm a decision of a task of a workflow withREST Call only ( I do not developp in c# or .net) ?
I try to use this URI Rest Call : /DocuWare/Platform/Workflows/{workflowId}/Instances/{instanceId}/Tasks/{taskId}/Decisions/{decisionId}/Confirm
with right WorkflowID / InstanceID / TaskID / DecisionID...
But i get this message in response :
<s:Message>There is an error in XML document (0, 0).</s:Message>
    <s:Exception>InvalidOperationException: There is an error in XML document (0, 0).</s:Exception>
So do someone know what is the structure of the Json Body (named ConfirmedData) ,ideally with a simple model ?
Thanks a lot,
stephane
Veröffentlicht Fri, 01 Feb 2019 11:16:55 GMT von Chema Lopez Developer
Hi.
I am having the same problem. I have created some classes to recreate the structure but I do not know what information I must give.
public class ConfirmedData {
  public ConfirmedField[] ConfirmedFields;
public class ConfirmedField {
  WFFormFieldValue Value;
public class WFFormFieldValue {
  public Object Item;
  public int ItemElementName;
If I call the REST method without information I get the response: 500 INTERNAL_SERVER_ERROR.
I hope someone could help.
Veröffentlicht Fri, 01 Feb 2019 11:55:07 GMT von Chema Lopez Developer
Hi.
I have been able to solve this by using an empty structure.
    ConfirmedData data = new ConfirmedData();
    HttpEntity<ConfirmedData> entity = new HttpEntity<>(data, headers);
    ResponseEntity<String> resp = rest.postForEntity(
        url + "/Workflows/" + wf + "/Instances/" + instance + "/Tasks/" + task + "/Decisions/" + decision + "/Confirm",
        entity, String.class);
Spring makes the JSON conversion process so I do not worry about the inner format.
I hope this can help.
Veröffentlicht Fri, 01 Feb 2019 15:10:52 GMT von BONNEAU Stephane CEO
Hello and thank you for your contribution...
I found a solution by onvokngthis method  :
/DocuWare/Platform/ControllerWorkflows/{workflowId}/Instances/{instanceId}/Tasks/{taskId}/Decisions/{decisionId}/Confirm
regards
